Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-17-2009, 07:13 PM
Clue144 is on a distinguished road
6 axle with 2 motors
ok this is a quik image i have made
those thick black lines are round tubes to spin ... my 6 axle
and i whant to spin them one at the time with 2 dc motor if its possible.
if motor 1 spins right and motor 2 spins left then the first axle will rotate.
if motor 1 spins left and motor 2 spins right then the second axle will rotate.
if motor 1 is stoped and motor 2 spins right then the third axle will rotate.
if motor 1 is stoped and motor 2 spins left then the fourth axle will rotate.
if motor 1 spins left and motor 2 is stoped then the fifth axle will rotate.
if motor 1 spins right and motor 2 is stoped then the sixth axle will rotate.
Ok i hope someone understand this, this would work if i know how to build it, I have a couple of gears but its seems impossible.
Can anyone help me, show me or explain how exactly i can do or give me another teory to make this ?
maybe 3 motors? dont whant to use 6 motors, thats my last option!
Old 01-19-2009, 09:23 AM
keebler303 is on a distinguished road
I don't see any sensible way to do that with 2 motors. With 3, it could be done without too much trouble, if you only want them to turn in 1 direction. You would need to use overrunning clutches or bearings, like whats on a bicycle. It would freewheel in one direction and drive in the other. You would need these mechanisms opposed on each pair of axles. To make them all turn the same way, you would need some gears to reverse the rotation of 3 of the axles. I think after all of the time and money put into that you would be better suited with 6 motors.
Maybe if you were more specific about what it is you are trying to do, how big the motors are, how you are controlling the motors, someone could suggest the best method to get the job done.
Matt
Need Help!- 15xt X-axle problem Masi Fadal 3 04-07-2008 10:39 AM
Need Help!- fanuc 10 m X axle improper NC adress maher Machine Problems, Solutions , Wireless DNC, serial port 0 04-04-2008 08:23 AM
Out of center axle turning? fizzman General Metalwork Discussion 10 09-26-2007 02:03 PM
Anyone uses beltdrive for y and x axle?? Bosen Open Source CNC Machine Designs 4 08-17-2006 11:17 PM
64x120 3-axle router cariboosigns Commercial CNC Wood Routers 1 04-03-2006 12:38 PM
