Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-17-2009, 06:23 PM
*Registered User*
thebluedirt is on a distinguished road
Skate Bearing Blocks?
Hi, everyone:
I'm building a small cnc machine, planning on using ebay linear bearings, and acme threaded rod for the lead screws.
Since i have a bunch of them on hand, I'm planning on using 6208 skate bearings for the leadscrews.
The skate bearings have an OD of 22mm. Does anyone know of a source of cheap bearing blocks to hold the bearings? Ideally, i'm looking for a 'pillow block' kind of mount, though even a regular block with holes for screws would work well.
My thought is to load two against each other to remove play. I know they will not be as good as a good set of AC bearings, but since I have them on hand...
anyone have ideas? I could make them with a cnc if I had a cnc I am sure I cannot be the first to need to mount some 6208's without the abililty to bore a precise 22mm hole...
Thanks in advance for ideas.....
Old 01-17-2009, 06:31 PM
ger21's Avatar
If you have a drill press, you can buy a 22mm forstner bit. CMT makes them, they're about $15. I've made some blocks from phenolic material I had on hand.
Old 01-27-2009, 09:50 PM
GreenvilleDave is on a distinguished road
That was me..
Hi, thanks!
that was me below asking the question-- I've switched userids.
I ended up taking the advice about the forstner bit, but then kind of did some 'yak shaving' and took the opportunity to play with RTV silicon. I posted the results here:
http://www.cnczone.com/forums/showthread.php?t=72436
Old 02-01-2009, 08:13 PM
cnccutter's Avatar
cnccutter is on a distinguished road
"If you have a drill press, you can buy a 22mm forstner bit. CMT makes them, they're about $15. I've made some blocks from phenolic material I had on hand.
Gerry"
Gerry, how did the phenolic bearing blocks hold up? I was planning on making some...
Old 02-04-2009, 12:01 AM
ahren's Avatar
ahren is on a distinguished road
Are you planning on turning the ACME rods down to 8 mm in diameter? That might negate a lot of the cost/hassle savings from re-using your bearings. With a half inch bearing, you can sandwich each side with a thrust bearing to hold the screws, and let the screw float in the radial bearing to avoid excessive axial loads to it. You can see an example of this on the "parts" page of my website.
That being said, I like your mold! Your parts definitely look good, and it's a nice way to make things if you don't have a CNC machine at your disposal.
Best regards,
Ahren
www.cncrouterparts.com
Old 02-04-2009, 06:16 AM
Hi, ahren:
Thanks for the reply. Yes, I found my way to your website-- your parts collection is nice.
Yes, my plan was to either turn the acme down to 8mm, or ( perhaps initially ) to use 5/16-18 threaded rod, which fits into the skate bearings just right.
Old 02-04-2009, 08:48 AM
ahren's Avatar
Dave,
If it's in your budget, I'd definitely go ACME -- all thread makes a pretty crappy lead screw. Additionally, while 5/16 "fits", it's probably at least 0.004" undersized. 8mm = 0.316", 5/16=0.312", and usually a screws major diameter is smaller than the stated size. This is a pretty poor fit for a bearing, and could lead to whip in your axis at even a moderate speed.
Best regards,
Ahren
Old 02-04-2009, 10:00 AM
Thanks for the info.
You make a good point about the tolerance on the allthread.
I've seen your bearing blocks in your store. Does the bearing block include the price of the 1/2" ID bearing?
Also, i'm curious, what do you see as the typical cost for those bearings?
I think you are right about acme vs allthread, but what's attractive is the per-piece price of skate bearings, @ < $1 per piece its hard to beat.
Old 02-04-2009, 10:13 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I used a combination of flange bearings and pillow blocks on my router.
I didn't use thrust bearings on it. I should have though. If the end play gets to be to much, I will replace those and install thrust bearings as well.
This is how I did my new lathe, except I used rolled ball screws with double nuts.
Very little backlash and no end play that is measurable.
Thrust bearings take up very little room and are pretty cheap. Same with flange bearings.
Lee
Old 02-04-2009, 10:41 AM
ahren's Avatar
Dave,
Yes, my bearing blocks include the cost of a 1/2" bearing. They're only about $2 from VXB if you buy 10 at a time, but I added them to the assembly to save people an extra order and shipping charge.
Best regards,
Ahren
  #11   Ban this user!
Old 02-04-2009, 05:57 PM
i think your decision to add them is wise-- most who want the blocks would need the bearings too.
do you make the parts in your store? they look nice. most people here know about them, i think most folks who opt not to use them are penny pinching.
Originally Posted by ahren View Post
Dave,
Best regards,
Ahren
  #12   Ban this user!
Old 02-04-2009, 08:53 PM
ahren's Avatar
Dave,
Thanks for the compliments. I make prototypes and small production runs on my equipment, but volume parts are made by my supplier, who uses top notch CNC equipment (Fadal 4020 machines). Most parts are tumble deburred after machining to give them a nice finish. All of my parts are made in the US, aside from the fasteners and bearings.
There's certainly nothing wrong with penny pinching -- my business depends on it! While I certainly enjoy selling parts, I also try to make sure people get the best possible solution for their machines and situation, which is why I like participating in these forums. After building two machines of my own, I have been through a lot of the pain that comes with doing things a little too cheaply .
Good luck with your build, and feel free to contact me if there's anything I can help with!
Best regards,
Ahren
Tags
bearing block
skate bearing supplier (sourced!) tankie Australia, New Zealand Club house 4 10-04-2007 06:52 PM
Lifespan of a Skate Bearing. Miata2k DIY-CNC Router Table Machines 9 09-22-2006 12:53 PM
skate bearing design paul langwade DIY-CNC Router Table Machines 1 07-29-2006 07:56 PM
Torsion box and Skate bearing thought spalm Linear and Rotary Motion 0 06-03-2005 03:19 PM
Skate Bearing Design coolman DIY-CNC Router Table Machines 11 05-20-2005 01:25 PM
