Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-13-2009, 09:03 AM
dgoddard is on a distinguished road
Question Ballscrew Advice?
I am converting a Grizzly G0602 mini-lathe to CNC and looking for some advice on ballscrews. I have a RF-31 mill/drill which I converted to CNC several years ago and used Rockford ballscrews with double ballnuts. Althougth everything works well, I have never been able to get the backlash below .003-.004". On the mill I did all the machining, etc. For the lathe, in the interest of my time, I as considering having the ballscrews machined and getting premade end supports. I came across homeshopcnc.com's site and all looks good on paper. Would like to hear from someone who is using their products. Searching the forum I came across some threads that were not so positive and some quite positive. Some threads recommended MiSumiusa.com as an alternative (lower prices). Any input as to how they compare in quality. Open to all suggestions as to best sources, etc. Goal is to be capable of turning X and Z axis to less than .001" tolerance.
ballscrew vs rack advice eloid Linear and Rotary Motion 8 03-03-2008 07:37 PM
Need ballscrew advice please cnczoner Linear and Rotary Motion 11 02-18-2008 11:52 AM
New and in need of some advice... well alot of advice! GoonShoes Bridgeport and Hardinge Mills 9 05-30-2007 07:03 AM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
ballscrew support idea / advice please DrStein99 Linear and Rotary Motion 8 04-29-2006 12:11 AM
