Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-12-2009, 12:49 PM
Ragnarok is on a distinguished road
Number of threads per inch in ballscrews
Hi
I want to know which are the advantages of having more or less threads per inch in the ballscrews, I know that if you have less threads per in you can achieve higher speeds, but this sacrifice precision, this will affect the load?.
I what to know more pros and cons, thanks a lot!!
Saludos!
Setting up threads/inch... venomx999 Machines running Mach Software 3 02-01-2007 01:17 AM
Set-up / Steps per Unit / Threads per Inch adda Mastercam 2 01-15-2007 04:29 PM
Ballscrews for Bridgeport with a 36 inch table needed mountainviewcnc Bridgeport and Hardinge Mills 2 06-20-2006 12:25 AM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 09:27 AM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
