Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-10-2009, 04:17 AM
kurthice is on a distinguished road
design of a feed drive for an NC lathe
Hi I'm new here. I'm pretty crap at mechanical design, but I have to design a feed drive for the X-axis of an NC lathe for a course project. I have to select the drive motor, ball screw, pulleys and timing belt. There are a lot of things i don't know, but my concern is how the pulleys can be connected to the motor shaft (can they be directly conncected to it) and to the screw shaft. I can select a ballscrew and a motor based on calculations, but the coupling of the elements is where the problems come.
For the screw shaft, I can choose between different end configurations, but i need a start point.
Do the pulleys require a key connention, or a press fit is acceptable? How can I connect the pulley to the motor shaft in the simplest way?
I apologize for the stupid questions, but I really need some advice.
Also, this is for a course project, and the simplest easiest solution (not necessarily working ) is what I'm truing to figure out.
Oh yeah, I forgot ..
Old 01-10-2009, 12:01 PM
kurthice, Try this www.jakobantriebstechnik.de
Dick Z
DZASTR
Old 01-10-2009, 12:43 PM
Al_The_Man's Avatar
Keyed pulleys are one of the most common and secure methods, but if you want a method without having to machine keyways, using Taper Bushed pulleys are just about as secure.
These lock the pulleys by means of a taper sleeve using allen set screws to lock into place.
Type E or GF here http://www.martinsprocket.com/2001/SecKa.pdf#K5
If you also need any sizing assistance, here is an Free Engineering program that may help.
http://www.electromate.com/technical...morgansoftware
Old 01-11-2009, 03:23 AM
thanks this is very helpful!
My greatest concern was how to secure the pulleys - I didn't know anything about the taper bushed pulleys.
Now I'll look for more information, like 3d models of such pulleys.
Is it ok to use such a pulley directly on the motor shaft?
Old 01-11-2009, 09:20 AM
Al_The_Man's Avatar
My Excello Knee mills use this method and I have never had a problem yet.
They clamp directly to a straight shaft.
Old 01-11-2009, 11:37 AM
Thanks a lot. I guess I'll be able to complete the design with this information
Tags
feed drive lathe
Help with design of stepper drive tobybirch007 Stepper Motors and Drives 13 01-30-2009 11:40 AM
New Machine Build- CNC Design from Scratch, w/Belt Drive stepinator CNC Wood Router Project Log 59 08-14-2008 07:56 AM
X Axis Drive Design cxixer DIY-CNC Router Table Machines 6 10-17-2007 09:31 PM
TL bar feed design. DJPdesign Haas Lathes 8 09-01-2007 10:58 PM
Belt-drive design cnczoner General Metal Working Machines 7 05-28-2004 12:48 AM
