Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-06-2009, 10:16 AM
jwest is on a distinguished road
which matieral for shaft
Hi, I'm building a budget cnc using linear bearings. But what material do you recomend for the shaft, I'm looking at around 15mm in diameter and 750mm long but should I go for mild steel or aluminium, or pay more and go for stainless steel? is there much of a difference?
Many thanks
Old 01-06-2009, 10:39 AM
diecutter is on a distinguished road
I would stay away from aluminum because it wears way too quickly. Stainless steel is pricey and hard to work with. Mild steel is ok, but drill rod is not much more expensive, has excellent finish and tolerance specs., and is available at all machinery supply companies such as MSC and Enco. I would go with a larger diameter rod for a span that long to increase rigidity without driving the cost up too much.
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
1/4 to 3/8 nema 23 shaft dgalaxy Stepper Motors and Drives 1 12-16-2006 12:28 AM
shaft couplers dgalaxy Benchtop Machines 4 02-01-2006 11:18 AM
shaft couplers do i need craftech DIY-CNC Router Table Machines 3 11-29-2004 09:26 AM
Shaft lube Zephrant General Metal Working Machines 5 06-12-2003 11:03 PM
