Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-26-2008, 12:12 PM
Karl Shoemaker is on a distinguished road
MAE stepper motor ID
Hello.
I am new to this forum and am hoping someone can help me. I work in a microbrewery and TRY to do all the maintenance that is asked of me but this is beyond my capabilities. We have a used bottle labeler that came with no paperwork. It has a MAE stepper motor that I believe is bad but I don't know how it is supposed to act. It ran fine for a few years. It seems to have good torque and runs smooth until I hook it up to the belt drive and then it stutters. Everything it drives turn smoothly and are not stuck. Anyway, my question is, what is this motor? How do I break down the #s to replace it. As best I can tell, it is no longer a current model. The only thing written on the label is - MAE HY200 3450 0350 AX08 it also has A35171. Can anyone please tell me what the specs or what would be a correct replacement for this motor?
Thanks for your time and any help, and HAVE A SAFE AND HAPPY NEW YEAR!
Karl.
Old 12-26-2008, 12:50 PM
lucas is on a distinguished road
The HY200 series are wide spread and very common.
Google on "HY200 3450"
One hit from this site:
Stepper ID help please.
Another one:
http://www.servotrade.it/en/promozio...id_prodotto=62
You should be able to find these quite easily, second hand, Ebay ...
But I doubt that the motor is defective unless it has really overheated or a mechanical problem: bearings.....
I would first check the driver and the power supply.
Regards,
Luc.
Old 12-26-2008, 01:59 PM
Thanks for your help, but, IF it were a bad motor, are you saying that the first 9 digits are the IDing digits? Will any MAE motor starting with "HY200 3450" replace mine? Again, this long # is the only thing I have to go by.
Thanks again, Karl.
Old 12-27-2008, 06:58 AM
The first 9 digits are indeed not enough.
The remaining ones indicate the coil current and other options like the winding configuration, shaft options etc..
use satellite dish actuator motor as a stepper motor ozni Stepper Motors and Drives 7 06-18-2010 08:55 PM
Stepper motor vs. Servo motor Tony611 General Electronics Discussion 28 11-19-2008 09:11 AM
Beltdrive-stepper motor-stepper motor driver Georg Stepper Motors and Drives 0 10-16-2007 05:56 PM
Stepper Motor Gallop Stepper Motors and Drives 4 06-08-2007 02:33 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 06:05 PM
