Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-17-2008, 09:24 PM
woodsnskins is on a distinguished road
Help with rotary table
I have a rotary table for a mill and would like to hold a 5" diameter cylinder using this rotary table. I do not need to move at a high rpm (7 - 8 rpm max)
I also have a 3 jaw chuck available.
Does anyone have any recommendation for the kind of fixture needed to support such a cylinder (5" diameter)?
thanks in advance
Old 12-18-2008, 05:58 AM
kawazuki is on a distinguished road
thanks in advance
What size r. table? Gonna need to be at least a 6"! Obviously a 5" chuck will hold the pipe but could distort it with the force required in a 3 jaw. 4 jaw better, 6 jaw best - also what accuracy in alignment do you require? 3 jaws are ok but an independant can be spot cock on!
Chuck mounting to table usually with back plate and either tee slots or screw adapter?
7 - 8 rpm on a rotary table is quite fast especially if manual - could be done with motorisation but still pretty rapid - edge speed of 125.6" / minute and 576 turns of the crank handle for a 1:72 geared table?
Need Help!- cnc rotary table iccirvr Benchtop Machines 1 03-01-2008 12:05 PM
How do you use a rotary table? ranchak General Metal Working Machines 0 01-30-2008 11:30 PM
Rotary table Piobaire HURCO 0 08-22-2007 08:30 AM
Looking for a rotary table gto7419 General Metal Working Machines 4 06-11-2006 08:37 PM
Rotary Table Req h_2_o General Metal Working Machines 9 02-08-2005 02:11 PM
