Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-16-2008, 12:28 PM
cor cor is offline
cor is on a distinguished road
Belt drive how to construct ?
I am planning to make a machine and want to use belts instead of
leadscrews now my question is how to construct it and what kind of gear
I need for it, it will be driven by 23 nema steppers i hope someone has a solution and hopely some drawings cq pictures thanks
cor
Old 12-16-2008, 12:37 PM
harryn is on a distinguished road
Hi - I am attempting a belt drive system as well. (early stage) There is a lot of information on the site www.brecoflex.com - they sell belt drive components, as well as others do also.
You can use the search function in the wood projects log - search on "belt drive".
Last but not least, I have been poking around various threads here and asking lots of dumb questions about belt drive based system. If you search on my user name and posts I have made, a lot of them will be related to your goal.
Old 12-16-2008, 03:03 PM
cor cor is offline
Thank you I will start reading your posts
I ,ll hope that I get smarter of it.
Old 12-29-2008, 01:04 AM
morgandeo is on a distinguished road
Re: Belt drive how to construct ?
Hi cor,
I can't done it but i will give you the basic information on belt drive.A Belt is a looped strip of flexible material, used to mechanically link two or more rotating shafts. They may be used as a source of motion, to efficiently transmit power, or to track relative movement. Belts are looped over pulleys.There are different types for belts available like flat belts,round belts,timing belts,vee belts etc.
Robotic Automation
" The joy of brightening other lives, bearing each others' burdens, easing other's loads and supplanting empty hearts and lives with generous gifts becomes for us the magic of Christmas."
My $20.00 X2 belt drive chukkie Benchtop Machines 46 01-31-2012 09:59 PM
Best belt drive ever! (If I do say so myself) Mike Everman Linear and Rotary Motion 279 01-08-2012 10:54 AM
Belt Drive Jerry In Maine Commercial CNC Wood Routers 0 05-12-2008 12:50 PM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 01:42 AM
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 10 03-01-2008 05:02 AM
