Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-14-2008, 08:04 PM
LinearMotionFan is on a distinguished road
TKH rails: Using 1 bearing block per rail?
Hi guys,
If we use THK/NSK/ect. style rail for the x-axis on a light etching machine, can we use just 1 bearing block per X-rail to support the gantry or is there too much play, so that we'd need 2 bearing separated apart a few inches to keep the gantry vertical? There will be very negligible contact force, just the weight (50 lb. max) of the gantry.
Thanks!
Old 12-14-2008, 09:53 PM
rowbare is on a distinguished road
You will have a severe racking problem if you only have one bearing per side. The cutting forces will make whichever side of the gantry you are cutting lag the other side.
How to cut a bearing block ? ringram2077 General Metalwork Discussion 14 04-02-2008 10:49 PM
Surplus rail slide and block johnnylisa Want To Buy...Need help! 1 01-30-2008 11:13 AM
Help with bearing block margni74 Linear and Rotary Motion 4 08-11-2007 05:47 PM
Linear rail and block calculation pequignotm Mechanical Calculations/Engineering Design 1 05-20-2007 05:13 PM
extending THK rails, rail alignment Cliff_J DIY-CNC Router Table Machines 1 05-28-2004 01:09 PM
