Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-09-2008, 03:05 PM
legendboy is on a distinguished road
Drill THK Rails? (searched already)
I bought a set of SHS15 rails and blocks on ebay without looking at them close enough.
These rails have mounting holes drilled and tapped on the bottom. I am wondering if it is even possible to drill out the tapped hole + counter sink so I am able to screw them from the top?
I imagine these rails are extremely hard. Maybe too hard for an operation like counterboring?
I am mounting them to a 2" thick dura-bar flat table.
Any ideas appreciated!
Old 12-10-2008, 06:18 AM
blackbeard52 is on a distinguished road
I have done just that. Carbide is the only way to do it. (Machinist techies dont bash me) I used masonary bits from a local hardware and they cut through it but use plenty of air to cool to prevent annealing. Drill through with 3/16 and counter bore with a larger bit. there will be a taper in the hole ....Just a suggestion.
Old 12-11-2008, 04:06 PM
I put them back on ebay and bought the correct rails. Hopefully i recoup my $
Newbie- CNC Knee Mill Conversion (I searched.) KyleH2 Knee Vertical Mills 48 07-02-2008 07:16 PM
searched, read, studied, still need help. nate BobCad-Cam 21 10-13-2007 01:51 PM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 03:21 PM
jgro machine - drill rod for rails? creative_mind JGRO Router Table Design 7 07-14-2005 10:12 PM
Ok, I've searched the board.... No luck... ccm TurboCNC 19 12-12-2004 11:04 PM
