| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Is that done, or deemed unnecessary by most? I understand there's a lot of variables to accuracy: I've read the ball screw primer thread, which emphasises good bearings as well as high quality lead screws and nuts/backlash setup. I've read the epoxy frame thread to death, for temperature stable rigid, vibration damped performance. High-res encoders limit feed rates for servo systems; not a concern for me (100 inches per minute would be plenty). I want to build a large format imaging device, on the scale of 2m x 3m x 0.5m travel. I'd like to achieve 0.0003" positioning resolution in the hope that I could get 0.0006" repeatability anywhere in the x/y plane. For my application it's mostly the repeatability that I want, but accuracy would come with it. I suppose I could easily afford to lose/gain 0.0003" over 5 or 10 inches if that was useful. I have contacts at Agilent but I know there's just about nothing they have in their catalogues that'd like the price of as a hobbyist individual :-) And nor would Optodyne, Reinshaw, etc. How are people using interferometers in the servo feedback loop? What about the measurement delay/lag? I'm particularly interested in being able to measure squareness of gantry and tool travel. Lasertex seem to sell a product called "LaserScaler", which would replace glass scales, it seems: http://www.lasertex.com.pl/index.php...=products&id=1 Given that this an imaging application, and I'm not actually loading up my servos with any kind of cutting etc., this makes things much easier for me - for example rigidity requirements of the design are much reduced. I think that if I also used something like the LaserScaler in my feedback loop, or as part of a start-up automatic calibration routine, I could also contemplate making my machine frame "portable" (maybe relocatable is a better word: being able to transport and then spend maybe one day to rig-up the machine would be immensely valuable). Thoughts appreciated... especially insights into the cost :-) |
| Since you're only moving an imaging device. Rather than worry about positioning your heavy gantry to that kind of accuracy, why not have a secondary high accuracy XYZ positioning device carried by the gantry? (high accuracy small movements are cheaper than large movements usually) |
| I looked up your link and found this: Measurement accuracy: - without meteo sensors 10ppm - with meteo sensors 1ppm - in vacuum 0.01ppm I guess it is safe to rule out the 'in vacuum' figure is being not applicable. ![]() However I cannot help thinking even 10ppm is a bit of overkill; unless you are planning on doing everything in a very tightly controlled environment, temperature, humidity and vibration.
I could even use steppers, seeing as there's no cutting loads to consider, and I can accept slow scanning speeds because that's going to be slow anyway. It's just that the startup autocal procedure I have in mind (approx. 1600 inches travel at the moment which I'd tolerate up to 30 minutes to complete) would benefit greatly from a fast servo setup. |
| It will be working most of the time in a temp/humidity controlled environment actually, 24-27 degC, 40-60% RH and I'll be doing my best to eliminate vibration if it becomes necessary. I was just curious if anybody out there was fixing any kind of permanent laser distance measurement onto their CNC machines in conjunction with or in lieu of glass scales. |
| Hope you are sitting down when you see the price. Wouldn't want you to fall down and hurt yourself. ![]() Laser interferometers are used as feedback devices in ultra-precision machine tools (like diamond turning lathes for making optics), high end CMMs, and semiconductor processing. Commonly used to calibrate machine tools but there is no way you are going to map out a 3 axis machine in 30 minutes. More like 6-10 hours. You can get glass scales with resolutions down to 1/10 of a micron and they are much more forgiving. Accuracy without external calibration can approach 1 micron. Are you trying to build something like a video CMM. http://www.acu-gage.com/ When building this type of equipment pitch, yaw, roll, straightness, and squareness errors from your slides will be your biggest design challenges. Maintaining less than .0003 abbe error over a 2 meter assembly will demand very high end bearings and a very rigid base. Bob
__________________ You can always spot the pioneers -- They're the ones with the arrows in their backs. |
Thanks for your thoughts, I appreciate it. I'll let you all know how much the LaserScalers come to, if they ever get back to me :-) |
#10
| Well, I got back an example system that they recently put together for 6-axis and I stripped out the components that I thought I would not need in my application (which was really just guessing, I need to talk to them more about what accessories I need), and it would appear that it comes to 9450 (euro?) without a Wollastone straightness kit (3000 by itself). So, this price is actually far better than I would have expected from Agilent. The full six-axis system with environmental monitoring/compensation was 31,000. |
| New Laser Engraver...Your thoughts and Feedback?? | velocitygraphix | Laser Engraving & Cutting Machines | 7 | 10-30-2008 08:12 AM |
| Open Loop to Closed Loop Stepper Conversion | beamhome | Stepper Motors and Drives | 0 | 01-02-2008 12:41 PM |
| Is there a way to cut THREAD without closed loop feedback? | cjchands | Mach Software (ArtSoft software) | 4 | 12-10-2007 11:29 PM |
| question on closed loop vs open loop (servo systems) | boonie | Servo Motors and Drives | 20 | 11-09-2007 01:30 PM |
| feedback isolator for laser | owhite | Laser Engraving & Cutting Machines | 9 | 04-14-2007 10:34 AM |
