Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-26-2008, 09:34 AM
bullethead67 is on a distinguished road
Stepper shaft adapters
I have a rack and pinion plasma table project i took over from someone else. Problem im having is locating an adapter to mount a gear that has a 5/16 bore to a stepper with a 1/4 inch shaft. The existing gears have this adapter already so I know they exist somewhere. I am currently adding a stepper so I can drive the gantry from both sides.
Old 11-26-2008, 10:16 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Are you talking about simple bushings? Mcmaster Carr has all sorts of bushings in different types of materials. You should be able to mark it for drilling the set screw holes. I have used several steel and bronze bushing like this on couplers that weren't the correct size.
Lee
How to cut stepper motor shaft? harry11733 DIY-CNC Router Table Machines 3 07-25-2008 11:01 AM
Need A Quote- 3 Shaft Adapters/Couplers klick0 Employment Opportunity 5 04-18-2008 12:37 AM
Stepper motor with 6mm shaft? juzwuz Stepper Motors and Drives 6 03-23-2008 03:19 AM
Stepper Motor, 6mm shaft juzwuz Want To Buy...Need help! 0 12-20-2007 04:38 PM
HP Laserjet II/III - STEPPER Shaft Rance DIY-CNC Router Table Machines 13 05-30-2006 07:10 AM
