| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| I got a 33 inch rail with 2 blocks..I want to know if i remove a blockl if the balls will fell off of if they are somehow contained within the block.I want to keep the removed block as a spare..Thanks Any instructions as how to proceed welcomed.
__________________ Andy |
| Hi Andy, If these linear guides are THK's HSR type it is OK to remove a block from the rail without using a dummy to park it on. I resently inspected and re-sealed 8 HSR 35 blocks from my X- and Y axis. You just slide it gently off the rail. Do not remove the end casings!! If you need to take the balls out to clean the whole thing, take one circulation of balls at a time. If the worst happen and you mix the balls between the 4 circulations, it is not a big deal. Their diameters are usually within 0,5 micron in difference within the same block. Blocks delivered on the same rail will usually have ball diameters of similar diameter ranges. But don't bet on it, never work with several blocks at a time. Between blocks from different rails you may find ball diameter differences up to 2-3 microns. (1 micron is 1/1000 mm). If you want to dismantle blocks comletely for inspection and re-sealing, send me a PM, and I will send more info and pictures. |
| Thanks ..there effectively thk...I will follow your advice..thanks again..
| No reason Andy, Keep them good. They are damn good stuff. |
| Is possible to change all the inside balls? someone know if is possible to know the exact replacement for these kind of truck? i have 4 HSR20 and have a lot of rust i want to at least completely change all the balls. |
| picking the best linear rail | HMD | Linear and Rotary Motion | 6 | 02-15-2008 09:15 AM |
| need help with linear rail choice. | HMD | Linear and Rotary Motion | 6 | 01-17-2008 05:50 PM |
| Linear Rail Alternative | m1911bldr | DIY-CNC Router Table Machines | 5 | 01-10-2008 10:43 PM |
| Linear Rail question | jdholbrook | Linear and Rotary Motion | 0 | 05-05-2006 04:27 PM |
