Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-21-2008, 05:44 PM
Cartierusm is on a distinguished road
Stepper Power Question
OK, so I'm building an automated machine for a specific operation and I'm going to use a stepper motors as I can control speed and location accurately.
Now I know if you up the volts you get better torque at higher speeds. SO what if I'm only going to be moving the stepper at 3 RPMs? What voltage would I need.
I'll be using 850 oz. in. stepper motors and probably wired bipolar parallel and use an inexpensive Probotix driver. At 3 RPM what oz in would I get and what power supply should I use?
Old 10-21-2008, 06:15 PM
irving2008 is on a distinguished road
it all depends on the speed/torque curve of the steppers. The reason for running higher voltages is to push more current through the inductive reactance of the motor winding earlier in the step and so move the 'knee point' of the curve further to the right (maintaining torque at higher revs). Without the speed/torque curve and the motor specifications (inductance/resistance) its impossible to say, however the data sheets I have suggest that you should typically get 80 - 90% of the holding torque below 500 steps/sec on a big motor, thats 2.5 rps or about 180rpm...
Old 10-21-2008, 07:16 PM
What kind of PS, since i'm not going for high speed can I get that torque with a 24V 6A? I'm trying to get all the torque I can, but don't want to spend a ton of money.
Old 10-21-2008, 07:20 PM
Gold Member
Mariss Freimanis is on a distinguished road
For 3 RPM, wire your motor in series and use as low of a supply voltage as the drive mfg permits. This will keep your supply as small and inexpensive as is possible. Your speed is so low that voltage will have no effect on performance.
Mariss
Old 10-21-2008, 07:38 PM
Thanks, I was always unsure about voltage pertaining to torque.
Old 10-21-2008, 08:59 PM
Gold Member
Voltage determines how 'quickly' current can be injected into and removed from a winding. 3RPM is 20 seconds per revolution which means you have 4 tenths of a second to inject and remove current. That is an eternity in electronic terms.
Current determines torque. At this speed the required current is reached in a few thousands of a second, it stays there for the 4/10 seconds and is then removed. The time spent injecting and removing the current is a tiny percentage of this time at such a low speed.
That is why I recommend you wire the motor in series. A series connection requires half as much current from your supply as a parallel connection. Your supply has to only half as big as for a parallel connection. There are no drawbacks at 3 RPM.
Mariss
Old 10-21-2008, 09:41 PM
In another thread in this section someone said this,"Make sure that the motor is wired bipolar parallel. I suspect that even the 4 wire motor is wired serial and that will kill the low speed power. Remember that the torque ratings are holding torque and the torque will drop off as soon as you move the motor. If you are using a 7/8" x 6tpi acme rod you will not have enough torque."
I know this is a different application but will wiring in series kill the low end torque? Thanks.
Old 10-22-2008, 10:17 AM
Gold Member
Torque = Amps times the number of turns of wire it passes through. In series, amps pass through twice as many turns of wire as it does in parallel. Only half as much current is needed for the same torque.
Mariss
Old 10-22-2008, 02:45 PM
Thanks.
Old 10-22-2008, 03:06 PM
TOTALLYRC is on a distinguished road
Hi, That was me.
Mariss
I learned something new today, which is why I read as much of the forums as I can.
stepper power question endgrainguy DIY-CNC Router Table Machines 2 03-03-2008 11:41 PM
Easy Question about Stepper Power Supplies kylecroft Stepper Motors and Drives 8 02-17-2007 12:36 AM
Stepper power jdholbrook Stepper Motors and Drives 0 06-25-2006 02:03 PM
Stepper power req's question ccm General Electronics Discussion 1 03-13-2004 03:33 PM
