| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hello I have a Denford Viceroy TDS1/1 with a worn cross slide acme nut. i would like to fit a ball screw as part of a CNC retro-fit. Here is a picture of the X slide in pieces. ![]() The acme screw is 1/2" diameter with a 0.1" pitch. It includes a gear for cross feed. I am seeking advice on the best and reasonably economic method of fitting a ball screw. The first question is what diameter screw would be appropriate. I could probably fit up to 3/4" max not including the nut. Is there a reliable seller of good used ball screws? Any advice would be much appreciated. |
| My main concern is the lack of space down the "tunnel" where the cross slide acme screw goes. I don't thin there will be room for the nut. I was wondering if the ball screw nut could be mounted in the far side of the cross slide. |
| Ball Bearing fitting EASY question...I think. | CNCWNTTOBE | Mechanical Calculations/Engineering Design | 6 | 07-29-2008 07:42 AM |
| Retro fitting a Mori Sieki to Mach3 Lathe | ErnieD | Machines running Mach Software | 0 | 11-15-2007 02:59 PM |
| what bearing fit with acme screw 1/2 -10(for cheap ball screw) | apex | Linear and Rotary Motion | 4 | 07-27-2007 12:15 PM |
| Coupler between stepper and slide ball screw | DeviousMW | Linear and Rotary Motion | 4 | 04-07-2007 11:16 PM |
| Retro fitting | new2this | Industrial Hobbies (Support forum) | 1 | 01-21-2006 07:21 PM |
