Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #13   Ban this user!
Old 10-23-2008, 03:31 PM
cely's Avatar
cely is on a distinguished road
Either. There are more off the shelf sizes that are round.
I can get 1/2" long, round spacers from 4-40 through 1/2-20 threads in 1/4" diameter for the small threads and 1/2" diameter for the large threads.
I would prefer to have tapped spacers made from pre-lubricated acetal, but can't find them.
I think that it would be a significant contribution....if we can find a good solution.
Poor planning on your part does NOT constitute an emergency on my part!
  #14   Ban this user!
Old 10-29-2008, 08:59 AM
BillTodd is on a distinguished road
I used PTFE (teflon) + M8 stainless steel threaded rod on my little engraver, seems to work well.
BTW the brass nut was an attempt to remove backlash, but because the M8 thread is fairly long and tight it proved unnecessary. The PTFE nut itself threaded M12 and is mounted to the ally bracket with a nylon nut. A dab of loctite stops the whole thing spinning.
  #15   Ban this user!
Old 11-10-2008, 03:14 PM
cely's Avatar
Thanks for the example. I'm not quite sure how the M8 Teflon nut is fixed to the bracket with Loctite. I didn't think anything would stick to Teflon. Teflon must run almost frictionless. I have looked but not found any pre-tapped Teflon spacers.
I too have found that there is less backlash with longer nut/spacers. A long nut/spacer has a lot of surface area in contact with the allthread rod. The goal is to get lots of contact area at very light pressures.
When I tap my own spacers, the fit is quite tight after the first pass with the tap. Depending on the allthread that I am going to use, I get a good fit after the 2nd to 5th pass with the tap. That's a good way to custom fit a spacer to a particular piece of allthread....however, I'm looking to keep my labor to a minimum and to design a solution that works with any piece of allthread. Compression or split nut seems to be the answer.
lead screw nuts wanted Bill Harrison General Metalwork Discussion 3 03-04-2008 12:37 AM
WTB: Lead screw nuts for Bridgeport Style MSC (Taiwan) knee mill for X and Y modernprecision Want To Buy...Need help! 5 03-03-2008 01:02 PM
Dumpster AB lead nuts SCHootie DIY-CNC Router Table Machines 4 02-18-2007 06:39 PM
Rotating lead nuts Tom Brown DIY-CNC Router Table Machines 69 09-29-2006 09:25 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
