| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hello all, Ima working on a small automation project ,where i need to move a flat plate along a particular axis(no ball screw,it just slides over a cross section).my travel is around 30-50mm. i want it as simple as possible. i can do this using small ball screw and a stepper.but i don't want to do any mechanical modification and the travel has to be limited by limits. second i can use a linear solenoid.but it moves so fast that it disturbs my job.but no need of limits. 3rd i can use linear actuator,but same problem as using a stepper motor and ball screw. so all i wanted to know is,is there some thing like slow moving solenoid?is it possible? i don't need any feedback.the plate has to just travel 50mm back and forward. some ideas from u guys will be appreciated. Regards |
If you simply want to move a fixed distance, full travel, back and forth, why not a pneumatic cylinder? Unless you need higher accuracy, the maybe consider a servobelt? http://[URL="http://www.bell-everman.com/Resources/ServoBelt_Techsheet_web.pdf"]www.bell-everman.com/Resources/ServoBelt_Techsheet_web.pdf[/URL] |
| sounds like you might want to use a pnuematic cylinder. if thespeed isto fast you can restrict the air which will slow the cylinder down. if you need a very smooth travel you can connect a speed control which is a cylinder with hydrualic fluid inside. these are very easy to use. |
| Assemble linear-actuator using off-the-shelf parts for < $600? | offtherack | Linear and Rotary Motion | 3 | 04-22-2008 03:42 AM |
| Rohlix Linear Actuator any good? | kenny1 | Linear and Rotary Motion | 4 | 04-15-2007 05:25 PM |
| linear actuator | coolman | Linear and Rotary Motion | 2 | 04-15-2006 04:33 PM |
| linear actuator | dgalaxy | CNC Plasma and Waterjet Machines | 4 | 03-06-2006 07:38 PM |
| Linear actuator! | JBV | Mechanical Calculations/Engineering Design | 60 | 10-21-2005 02:12 PM |
