Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 09-09-2008, 09:07 AM
theatrewizard is on a distinguished road
UHMW alternative?
I have some slide bushings, currently made out of uhmw, for an aluminum piece....not unlike a large sliding glass door frame, moving in its threshold.
The uhmw is working o.k., but the fit and finish of the individual bushing parts leave a little to be disired. They work , but when I go to mass produce, I want a "clean" set of parts to assemble. Are there any other choices besides UHMW?
They will have a load, but low speed, and not more than 1.5 feet of travel.
Any help would be great.
Chris
the early bird gets the worm, but the second mouse gets the cheese...
Old 09-09-2008, 12:50 PM
Delrin will probably work very well. Use a small amount of lubricant such as soft wax or a thin film of vaseline.
Old 09-09-2008, 12:51 PM
Mike Everman is on a distinguished road
Nylatron or Delrin AF (teflon filled), maybe. There's a few materials that are typically under the heading of "wear strip" or somesuch. Mcmaster has a lot of different bushing appropriate materials.
Mike Visit my projects blog at: http://mikeeverman.com/
http://www.bell-evermannews.com/ http://www.bell-everman.com
Old 09-09-2008, 01:25 PM
Thanks, guys. Delrin AF is on order.
Chris
Old 09-11-2008, 09:18 PM
Dougal is on a distinguished road
Delrin is similar to acetal, it isn't as tough as UHMWPE, but cleans up very nicely after machining.
Old 09-12-2008, 08:44 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Getting the correct cutter geometry, DOC, feeds and speeds and your machine should cut UHMW perfectly.
I agree that it is not as "fun" as other materials to machine.
Nylon is kinda fussy as well.
www.integratedmechanical.ca
Old 10-15-2008, 09:19 AM
AlienSteve is on a distinguished road
Do a Google for "nylon humidity" and you'll see why you don't want to use nylon.
UHMW table MBG DIY-CNC Router Table Machines 18 02-19-2008 04:54 AM
Where to buy UHMW Breaker DIY-CNC Router Table Machines 10 02-04-2008 10:41 AM
UHMW for ACME Nut? Thinwater Linear and Rotary Motion 10 01-17-2008 11:57 AM
UHMW Polyethylene Eric Nelson CNCzone Club House 2 01-26-2005 05:15 PM
melting UHMW Hobbiest DIY-CNC Router Table Machines 9 02-09-2004 04:42 PM
