| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I have been tasked with fitting a new 20hp AC motor to a test dyno. I have to get the motor shaft and the machines drive shaft within .010" concentricity and 1/2 degree angle. How do I indicate the two shafts to verify proper alignment? I haven't thought of an easy way to do it yet. Any tricks? Thanks Matt |
| That sort of accuracy can be achieved (assuming you are butting shaft ends to each other) with rulers/straight edges at 0 and 90 degree positions. Get 0 degrees right, do the same at 90 degrees, keep going back to the zero test until both are OK. Alternatively mount a flat ended flange on each shaft, and align until you have have a very even gap using a piece of paper to check the gap.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
| Clamp the indicator to the machine shaft. Line up the motor shaft as good as possible by eye. Indicate on the motor shaft near the end and then three or four inches further back. Adjust the motor to get the two readings the same; that is the same reading at the same position on the motor shaft. It does not matter if the motor shaft is not true to the machine shaft, if the TIR is the same at the end and further back the two shafts are parallel; Now you have the shafts parallel you can figure out what direction to move the motor to get them aligned; if you are lucky it will be a case of shimming it up the same amount at all the mounting bolts.
| You just need a 5/16" piece of HSS tool stock as a precision spacer against the small shaft. Think outside the square. (oops circle).
| Stepper motor with 6mm shaft? | juzwuz | Stepper Motors and Drives | 6 | 03-23-2008 03:19 AM |
| Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft | DonW | DIY-CNC Router Table Machines | 7 | 03-17-2008 04:58 PM |
| DC Motor shaft | wjfiles | General Metalwork Discussion | 2 | 08-09-2007 01:51 PM |
| aligning parts question | sdantonio | General Metalwork Discussion | 11 | 06-29-2006 09:42 PM |
| Problems aligning motor with lead screw. | SCCoupe | DIY-CNC Router Table Machines | 11 | 02-15-2005 07:33 PM |
