Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-25-2008, 08:28 AM
themonster is on a distinguished road
Steps per Inch / mm
Hi i'm trying to calculate my steps per mm for mach 3.
I am using an 8mm threaded rod at 1.25mm pitch for the lead screw.
I have the FL57STH76-2808B-1 Motors: 1.8degree
how do i calculate the steps per mm for mach 3. Also do i put the input in as steps per mm or inch. (i am using mm as the native units)
Old 08-25-2008, 09:08 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Welcome to the CNCZone. I assume you've checked the MACH3 manual pages 5-10 through 5-13 and found them a bit confusing? (http://www.machsupport.com/docs/Mach3Mill_1.84.pdf)
Maybe this will be helpful: (maybe not - but gives you something to think about)
(STEPS per REV)*(THREADS per unit)*(1/(Controller Stepping FACTOR))
STEPS per REV for your 1.8 degree motor this is 200 (A most common setting for many Stepper Motors)
THREADS per unit For Imperial threads: pitch is 1/TPI -Threads per Inch. But in the above solution you'd use TPI. Your mileage may vary with the mms.
Controller Stepping FACTOR for Full Step = 1; 1/2 Step = 2, 1/4 Step = 4; etc
Then, MACH 3 also has a means to calibrate the axis to fine tune your system - see page 5-13.
Hope thats helpful - Jim
ger21 has a nice answer of two here on the site - too. You'd need to wait for his response - or do a search
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Procedures to calculate steps per inch DrStein99 LinuxCNC (formerly EMC2) 5 08-17-2008 08:53 AM
steps per inch Chris Tucker Linear and Rotary Motion 12 08-14-2008 08:50 AM
Need Help!- 10160 steps to move 1-inch?? Marmot_Militia Mach Software (ArtSoft software) 5 07-15-2008 12:27 PM
Set-up / Steps per Unit / Threads per Inch adda Mastercam 2 01-15-2007 05:29 PM
Steps per inch formula, What I am doing wrong? Noah Gecko Drives 13 05-27-2004 07:56 PM
