Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-22-2008, 05:44 PM
Mcyoda is on a distinguished road
Grease Zerk For THK bearing block.
I have THK SHS 45 and HSR25. I have hard time finding the grease zerk. I really don't know what size is the zerk. Does anyone use of that and have reference to that zerks?
Old 08-22-2008, 08:55 PM
Machtool is on a distinguished road
My catalog shows B-PT1/8 for the SHS 45. That’s British Standard Taper Pipe. BSPT -1/8”
HSR 25 shows an M6 metric port. That will be standard M6 x 1mm pitch.
Regards Phil.
Old 08-22-2008, 10:35 PM
Regards Phil.
I don't think I am going to one in the USA but the M6 should be no problem.
Rocky
Old 08-23-2008, 12:57 AM
Rocky
Some guys I recommended this company too had good results when they were looking for some BSW bolts.
http://www.britishfasteners.com/mm5/...egory_Code=300
You could try a NPT, I’m sure that’s been done; yours are 27 TPI the British will be 28 TPI. Although you will probably get some crap in there from the cross threading.
You will have more luck finding them if you look for “grease nipple” rather than Zerk. That’s a particularly American term.
McMaster Carr also have them. Page 2133, of the catalog. Part Numbers 2408K11, 2408K12, 2408K14, & 2408K13.
Regards Phil.
Linear bearing grease Claude Boudreau Linear and Rotary Motion 12 04-11-2008 12:33 AM
How to cut a bearing block ? ringram2077 General Metalwork Discussion 14 04-02-2008 10:49 PM
Help with bearing block margni74 Linear and Rotary Motion 4 08-11-2007 05:47 PM
Which Bearing grease? skyline Linear and Rotary Motion 0 04-15-2007 03:10 PM
Bearing Grease georgebarr DIY-CNC Router Table Machines 1 06-06-2005 05:07 PM
