Results 1 to 5 of 5
Thread: How to calculate belt step.
    Jul 2008
    I am kind of familiar with step motor and screw but when come to belt and servomotor I am lost.
    For example I plan to use single end belt system with reduction of 4.8:1 similar to the attached picture.
    The main belt: T5
    Main pulley drive T5: 20 teeth
    Belt Reducer: 4.8
    Servomotor RPM max: 3200
    steps for Mach: ?
    Encoder: 500 CPR
    What other information I need to calculate the steps Mach3?
    Rocky
    Attached Thumbnails Attached Thumbnails How to calculate belt step.-motor_plate4.jpg   How to calculate belt step.-belt_1.jpg
    Aug 2005
    knoxville,usa
    Actually I will chime in...I am not 100% but looks to me that the motor step i.e. 180 steps per rev divided by diameter of pulley should give inches or mm per rev...or pretty close, then fine tune in Mach diag. screen
    May 2008
    "The main belt: T5
    Belt Reducer: 4.8
    steps for Mach: ?
    Encoder: 500 CPR"
    OK,
    T5 is 5mm per tooth.
    One rev of drive pinion goes 100mm.
    Input reduction means 4.8 revs at motor for 100mm linear travel.
    4.8*180 steps per 100mm (.864steps/mm)
    4.8*500 encoder counts per 100mm (2.4 counts per mm)
    Any way you slice it, you'll want more resolution. US digital can get you 8,000 encoder counts after quadrature.
    Mike Visit my projects blog at: http://mikeeverman.com/
    http://www.bell-evermannews.com/ http://www.bell-everman.com
    Jul 2008
    Quote Originally Posted by Mike Everman View Post
    "The main belt: T5
    Belt Reducer: 4.8
    steps for Mach: ?
    Encoder: 500 CPR"
    OK,
    Last few days I tried to digest the whole calculation. I am even more confused at the moment.
    1. Where do you get the 180 steps from?
    2. Why is 0.864 steps/mm not 8.64?
    3. 4.8*500 ecoder counts per 100mm ( isn't it should be 24 counts per mm?)
    May 2008
    No wonder there was no response! Everyone was thinking: "what is this yutz Everman talking about??"
    You are of course right. It is 8.64/mm on cardinal steps, and 24/mm on encoder counts, and I neglected to consider microstepping in my sleepy post, so you will have plenty of resolution with even modest microstepping. I would, however go with higher encoder resolution if you are going to use a servomotor.
    I was thinking just of cardinal steps, which for most steppers is 180 per turn.
    I sincerely apologize for my sloppy help! I should have waited till I'd had some sleep before opening my virtual mouth.
    Cheers.
    1. Need Sherline Belt & qestion on X2 Belt Drive?
      By Oldboy in forum Benchtop Machines
      Last Post: 03-06-2008, 01:42 AM
    2. bridgeport 2j belt for step pulley
      By patrick71100 in forum Bridgeport and Hardinge Mills
      Last Post: 11-02-2007, 12:28 AM
    3. Proper way to calculate steps/unit for belt drive?
      By MrBean in forum DIY CNC Router Table Machines
      Last Post: 03-30-2007, 10:48 PM
    4. Belt size/spec for Sieg X3 driving belt
      By rashid11 in forum X3/SX3/G0619/G0463
      Last Post: 02-10-2007, 08:01 AM
    5. Seeking Belt Sander Belt Source 6 x 48
      By Dugg in forum General Metal Working Machines
      Last Post: 12-24-2006, 10:48 AM
