| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Is there an alternative fixing method for Acme screw threads that doesn't need them to be machined. I have found a supplier of threads at a great price but the end machining cost makes them to dear, so i am trying to find a way to mount them without having to have the ends machined. any input would be helpful |
| It is doable I think. It may not be a perfect setup, but you can do it. I use pillow block bearings on my ball screws on the router. My screws are turned down, but if you get a good fitting bearing with an eccentric locking collar, it would work. You would need a larger coupling to the motor also. That part will be the hard one to find. You could drill a hole in the end of the screw and then insert the small shaft of the motor assuming the Acme is large enough. That would be difficult to do without a lathe. If you had a lathe, then you wouldn't need to worry about turning them down though. A minilathe will do acme rod just fine.
__________________ Lee |
| Thanks Leeway for your input might be a lot of hassell but a good cost saving. cnclite1 :- i will be looking at 16mm / 20mm Thanks gerry that gives me food for thought i will have to have a good look around for parts that will work. yhanks for all the input |
| Leeway you sugested eccentric collar bearings (usually Fafnir (now Timken)) but they should only be used for non-reversing loads. What you should use here is Sealmaster($$$$) McGill, or Dodge with the squeeze-lock collars. The eccentric will come loose with the inertia of the reversing load, where the squeeze-lock type grips evenly around the shaft and won't come loose. |
On my Y axis, I use the same type bearing, but flange style. The other end of it though is a bronze flanged bushing also with wave washers. These have to be adjusted periodically and are not maint. free, but induce only little play and within my tolerances. For the ease of installation and low initial cost, I feel it was a fair trade off. I had intended to build new mounts with proper bearings and will likely do that now that I have my mill running, but it's not critical for me right now because it is working so well. The most play I have measured on the router after it was tuned was .008" and that was before I installed the second ball nuts. Here is a link to pillow blocks. These don't have the eccentric collar and would like work well with a set screw inserted into the screw. Here are the flanged type I used. Here are the 4 bolt flange type. If you have plenty of screw and room, you could mount the flange bearings back to back on a plate with a spring in between and would have a decent setup. One other thing, since you won't be turning journals on the screws, you can lock these bearings in place on the shafts using a locking nut configuration on both sides. 4 nuts total. Takes some real estate, but works pretty well.
| Here is a link to an example of one of the units I mentioned. Advise-- SHOP AROUND. http://www.applied.com/apps/commerce...169&r=0&type=a To look up sources in the yellow pages, look under POWER TRANSMISSION EQUIPMENT. |
#10
| Many thanks again for the input guys, I think leeway has the better option to suit my needs as this will be my first build and cost is at a premium, that’s why getting the ends turned down is not an option at this stage. I want to build as cheap as possible but not to cheap as to sacrifice quality, you know the story thanks again |
| Tags |
| acme screw thread ends |
| Machining Ball screw ends | Ferrari2007 | DIY-CNC Router Table Machines | 4 | 05-06-2008 08:30 AM |
| how to thread a 5/16 inch rod at both ends only | Saravanan25 | G-Code Programing | 14 | 01-24-2008 08:19 PM |
| How do you turn-down the ends on a ball-screw? | samualt | General Metalwork Discussion | 12 | 10-15-2007 11:41 AM |
| Machining the ends of ballscrews & ball screw size | Zumba | Linear and Rotary Motion | 4 | 02-15-2006 11:47 AM |
| Ballscrews with machined ends for CNC conversions | ngr1 | Benchtop Machines | 0 | 09-09-2005 02:47 PM |
