Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-12-2008, 10:40 AM
Ferrari2007 is on a distinguished road
Thompson End Block Tech Specs
I purchased a Thomposon Ballscrew End block from McMaster Carr their part number 60755K15. This is for a 1" ballscrew. I am looking for a spec sheet to this end block to give to a machinist who is going to machine the ballscrews to fit this end block.
I have not had any luck getting a data sheet from McMaster, and do not have a Thompson part number. Any ideas or suggestions?
I do know the inside diameter of the block to be 25/32", is this as simple as having the machinist turn the ball screw for that diameter, put shoulder to match the bearing race and cut threads on the end? Maybe I am over complicatiing this, but it would be great to have a spec sheet on the parts I am using.
Thanks in advance for your help.
3/4" thompson rail and 7" thompson bearing Ed Williams Linear and Rotary Motion 3 03-16-2008 12:05 PM
Thompson Rod T Supports?? fritts Linear and Rotary Motion 1 04-20-2006 07:25 AM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 01:52 AM
Stepper Specs (Was Servo Specs) plexer Stepper Motors and Drives 1 09-29-2005 10:28 AM
thk versus thompson newguy DIY-CNC Router Table Machines 5 04-19-2004 01:45 PM
