Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-09-2008, 01:47 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
Question Trying to find ballscrew to stepper couplers. Metric to Imperial?
Hi folks,
I'm watching a few auctions on e-bay at the moment for ballscrews and rails. If I can sneak in there at the last minute they might be decent value! But the screws are metric 16mm, and the steppers I'm looking at on a different site have imperial shafts. 1/2 inch and 3/4 inch.
Does anyone know where I could get couplers for these sizes?
I was intending to buy everything from the states because of the huge savings on the exchange rate, but I've come across these and they're good value at the current price.
So anyone know where I could get metric to imperial couplers? Thanks.
PS: These will be for my new machine.....metal, geckos, HF spindle.....build thread to follow in a few weeks!
Old 08-09-2008, 05:40 PM
Zumba is on a distinguished road
You need to a machine a journal on the ends of the ballscrews to properly mount them in the bearing blocks. The journal can be machined to an imperial size.
Old 08-10-2008, 04:41 AM
Hirudin's Avatar
Hirudin is on a distinguished road
I've been looking a little on eBay as well (looking for 1/2 to 1/2 helical couplers). Here's the closest to what you're asking for that I've seen...
http://cgi.ebay.com/Helical-Products...QQcmdZViewItem
The auction doesn't say anything about international shipping though.
Another option is the "spider" or "lovejoy" (I think they're generally considered the same) type couplings that come in 3 separate pieces. It looks like you could buy whatever sizes you want and hook them together.
From what I've seen on eBay it looks like you might get better prices over here...
https://sdp-si.com/web/html/couplings.htm
Machining the ball screws to an imperial measurement would certainly work, but it might be a good idea to stick with the system of the screw in case you want to sell them in the future. It may be slightly harder to sell 16 mm screws with, say, 3/8" journals.
Old 08-10-2008, 06:18 AM
Question
Thanks folks....one other question. Does anyone know where I can buy or get the couplers machined with an internal key way to accept a high torque stepper like the NEMA 42? :
http://www.anaheimautomation.com/man...ec%20Sheet.pdf
Old 08-11-2008, 11:29 AM
Zappautomation is on a distinguished road
Are you looking at putting a 42 frame stepper on a 16mm ball screw?
The best option is to maching the ball screws to a metric size and then bore out one of the coupling ends to suit the motor you want.
Zapp Automation Ltd
www.slidesandballscrews.com
Old 08-11-2008, 11:41 AM
Thanks zap. I contacted a ballscrew supplier and they said that they could machine couplers to match imperial stepper shafts, and that the key on the stepper shaft can be removed.
Old 08-11-2008, 11:47 AM
ambrosefx is on a distinguished road
Send me your specs
Send me your specs and I can give you a qoute on custom machined solid shaft to shaft couplers. Spec out steel, brass, aluminum, plastic ETC
ambrosefx@cox.net
I work CHEAP
Bryan
Change from metric to imperial cijunet Mastercam 3 12-09-2007 11:51 PM
metric vs. imperial acme screws? carsonau DIY-CNC Router Table Machines 7 11-09-2007 02:06 AM
Metric or Imperial Ball Screws chris1407 Australia, New Zealand Club house 3 08-07-2007 05:59 PM
Converting from metric to imperial Pharkas Mastercam 1 05-04-2007 10:46 AM
Metric mm or Imperial inches? Please help. alexccmeister Benchtop Machines 14 02-21-2007 08:19 PM
