Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-08-2008, 06:30 PM
Apples's Avatar
Apples is on a distinguished road
Cold rolled steel, flats or square for use as rails.
So assuming I'm going to use cold rolled flat or square for linear rails with bearings.
I have a couple of concerns about using cold rolled, mainly with the issue of rusting.
So,
1. If I get the cold rolled rail surface ground for tighter accuracy, will a surface ground rail rust more quickly than a non ground rail?
2. If I was to use the same cold rolled but this time it was hardened and ground. Would it resist the rust more?
3. How do I stop it from rusting? I can't paint it as it will have bearings running across it.
4. Can I get the steel coated with something to stop it from rusting? Chrome would be nice but $$$$.
5. What if I used stainless steel for a rail. Would it be okay to use as an unmachined length, or would it need surface grinding as well? Is it more parrallel and as straight as cold rolled steel or is it not as straight etc?
Cheers,
Peter
My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
Old 08-08-2008, 07:38 PM
Karl_T's Avatar
Karl_T is on a distinguished road
You don't say what environment. I've had cold rolled parts in my shop for years with only a film of oil for protection. I keep the shop dry, AC in summer, heat in winter.
There's an inexpensive electroless nickel chrome available from Caswell
http://www.caswellplating.com/
that you might consider.
Stainless steel would be a good choice for corrosive environment.
Karl
Old 08-08-2008, 08:02 PM
Apples's Avatar
The environment would be just in a shed/garage. No snow, little rain each year.
Does get humid when hot.
Maybe use something like "dry glide" I think it is called. Where wd-40 is wet and will attract dust etc the dry glide stuff will not.
Are stainless steel flats and square, 1"x1" and say 1/2"x3" more dimentionaly accurate compared to cold roll of the same dimensions?
Old 08-08-2008, 08:20 PM
CarbideBob is on a distinguished road
Cold rolled steels are full of internal stresses. Over time they will warp and twist as the stresses relax.
They must be stress relived if you want any kind of long term dimensional stability. This is a really big problem if they are machined on one side or subject to uneven loading (read rollers loading two sides of the bar)
Won't you need a hardened surface for the rollers to ride on?
You could spray the thing down with WD-40 after every use but hard chroming then finish grinding is the best bet.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Karl_T's Avatar
You'll get rusting with steel in your situation. A dry lube won't help much.
You can order most all materials with the tolerance you need for dimensions. Tighter tolerance = more $
Karl
Old 08-08-2008, 09:00 PM
Apples's Avatar
Here is what the rail is for:
Will only be designing gantry as single side drive. Round figures,
gantry will be about 5ft wide, in shape of triangle. Bearings will be
mounted on a truck/carrage that is say 2ft long. Table size 4'x4'.
Will either use those concave type bearings or normal flat bearings.
Will be for a slow moving gas cutting table. No fast speeds.
Rails dimentions rough idea either square 1"x1" or flat 1/2"x3".
CarbideBob
Well I don't know. Looking at the torchmate machines all they reccommend is using cold rolled flat for rails.
I don't need cnc mill or router accuracy, for oxy fuel cut plate. I might have to ask some torchmate users how their cold rolled steel rails are holding up.
Old 08-08-2008, 09:20 PM
Well take my advice with a grain of salt as the stuff I work on is bit different than most of the stuff here. High production equipment with million cycle warranties, so the advice from others here may be better suited than mine.. Myself, I would never even consider using cold roll in a machine structure without stress relief.
Want to stress relive it yourself? Put your steel in the bottom of a big campfire. Bury it in the cinders and let it cool gradually over a couple of days.
Or, if you live in Michigan just leave it outside through the summer and winter for 2 to 3 years. Before the days of just in time this is what Cadillac did to all their engine blocks.
Bob
Old 08-08-2008, 10:04 PM
Karl_T's Avatar
For what you're doing, cold rolled is your best bet. Don't do any of that put it in the fire stuff. You'll screw it up. Cold roll will warp if you machine one side off on a long piece. Use full dimension, as ordered, material and you won't have trouble.
I'd be tempted to just spray paint your unit for protection. Keep the coating thin where it might effect accuracy.
Karl
Old 08-08-2008, 11:02 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.sherwin-automotive.com/pr...?product=40331
give a wet rag of rust mort to it , and it shouldn't rust ,if it ever does wipe it down again
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 08-08-2008, 11:37 PM
Apples's Avatar
Karl_T
I think that the PlasmaCam machines are just cam followers onto painted steel, come to think of it.
dertsap
rust mort
Never used this stuff before. Have used some "rust inhibitor" on chassis of old landrover then painted over with paint.
Will the "rust mort", or should I say does it have to go onto a rust surface, or can it go on a new clean surface and protect it from rust?
Old 08-09-2008, 12:22 AM
dertsap's Avatar
Gold Member
generally it's to go on a rusted surface but it will protect the surface as well
ive used it a fair bit on vehicles and stuff and it works great
Hot rolled steel angle to reinforce my mill column? Oldmanandhistoy Benchtop Machines 2 07-21-2008 10:35 AM
Stainless Steel / Aluminum Cut and Rolled ukchris Employment Opportunity 3 01-18-2007 08:09 AM
Which is better, round or square rails? digits General Metal Working Machines 5 11-13-2006 06:09 AM
Machining A36 Hot Rolled Steel SurfRunner General Metalwork Discussion 16 10-31-2006 01:13 PM
Need to cut 1 x 4 cold rolled steel - Product Review jderou General Metal Working Machines 17 07-06-2005 11:24 AM
