| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Looking at somehow fabricating a rotating axis in the middle of the CNC table in order to tune the rails into one plane. Was thinking somehow of using thrust bearings & radial bearings on the axis, then attaching sort triangular rods to it with a dial on the end to test the rails all around. Any ideas? |
| Let the moving part draw lines. 3-4-5 triangle is 90 degrees. A 5-12-13 triangle is too. Draw a base line, then check other axis movement from it. Get the base line STRAIGHT first. Then the (intended) right angle line STRAIGHT Now ensure the right angle lines are at 90 degrees to the base lie. Draw a right angle (using 3-4-5) from one end of the base line to a point A from A' Draw a second right angle (using 3-4-5) from the other end of the base line to a point B from B' The distance from A' to B' should be the same as A to B Mark a point C' halfway between A' and B' Mark a point C halfway between A and B Draw a line between C and C'. That line SHOULD BE 90 degrees to the base line. At least you will halve your 3-4-5 errors. As for getting the level correct in Z a clear plastic tube with some water, an assistant should soon get all the corners at the same height. Small diameter medical tubing is ideal.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| New Machine Design book from Alexander Slocum (of Precision Machine Design) | toastydeath | General Metal Working Machines | 10 | 11-25-2009 10:37 AM |
| My CNC design | dex918 | General Metal Working Machines | 24 | 02-26-2008 09:44 AM |
| Finding Engineering Design Software For Automatic Machine Design | hellokitty | General CAM Discussion | 0 | 01-06-2008 12:39 AM |
| design help | yousif_1985 | Mechanical Calculations/Engineering Design | 1 | 11-29-2007 08:47 AM |
| Could someone look at this design? | candle | DIY-CNC Router Table Machines | 34 | 09-23-2006 04:10 PM |
