Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-15-2008, 09:34 AM
diabolical7 is on a distinguished road
Rack & Pinion Calculation
I tried using the search function but to no avail:
I'm trying to calculate deg/mm for a rack and pinion
but I am not sure how I can do this please advise
Old 07-15-2008, 10:09 AM
ger21's Avatar
The pitch diameter of the pinion is how far it travels in one revolution. Divide that by 360 to get mm/deg. Then take the inverse to get deg/mm.
Old 07-15-2008, 10:30 AM
jpgdesigns is on a distinguished road
for a little more info: http://en.wikipedia.org/wiki/Gear#Pitch
Old 07-15-2008, 10:40 AM
pitch diameter is the distance from the end of one tooth to the other right?
Old 07-15-2008, 11:56 AM
Al_The_Man's Avatar
The pitch dia or pitch circle is used to calculate the distance the centre of the pinion would travel in one revolution. It usually falls below the tip of the pinion, at roughly half to one third the height of the tooth, depending on pitch angle.
If you go to any of the gear manuf. they should show the description of all the terms.
Boston Gear, Martin, or the free set of data books from SPI/Stock Drive Products.
Rack and Pinion ozturbo Linear and Rotary Motion 3 03-19-2008 07:20 PM
rack and pinion senor J. Linear and Rotary Motion 7 11-17-2005 04:21 PM
I need rack and pinion Help t0m CNC Plasma and Waterjet Machines 9 11-16-2005 01:14 PM
Rack & pinion coolman DIY-CNC Router Table Machines 3 11-30-2004 10:57 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
