Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-13-2008, 05:05 PM
java77man is on a distinguished road
Plastic bearings in Ball Nut???
I decided to disassemble a ballscrew/nut that I purchased on ebay. It was
listed as having "some wear", when I received it, I figured it was indeed
too bad to use unless I "fixed" the backlash in the nut.
However, as I disassembled the nut, out came some ball bearings that were
translucent plastic, not steel. I collected the plastic bearings into one small bottle and the steel ones into another. When done, there was as many
plastic bearings as steel.
Has anyone ever heard of "plastic bearings" in ball nuts???
Maybe I have a shot at "fixing" this ballnut by replacing these plastic bearings
and the steel ones with "all steel", what say anyone?
Jesse
(java77man)
Old 07-13-2008, 06:25 PM
Mike Nash is on a distinguished road
I was just reading about this last week in a PDF someone had posted a link to. But it's at work and I don't remember where I got it. The plastic balls are spacers to reduce friction and that "gritty" feel a tight ballnut can have when the steel balls slide against one another. They reduce the load capacity by about half due to only having half the steel balls.
Old 07-14-2008, 01:31 PM
Plastic vs Steel for bearings
Mike:
Thought I was going crazy for a second. Thanks, for the info about
plastic used for spacers. Definitely, I will try to replace with all steel and
see if that helps.
Thanks again.
Jesse
(Java77man)
Old 07-15-2008, 03:11 AM
ironDigit is on a distinguished road
please do note that,
ballnuts are filled with not equally created steels balls(the ones that are all steel).
i heard of manufacturers using smaller balls as spacers in between all the slightly large balls to reduce friction when the run against eachother and this is an aspect to wreckon with if you want to end up with a smooth ballscrew.
i neer heared about plastic balls but it does stroke with spacing the actual loadbearingballs cause i can imagine what happen when they run against eachother.
so lots o measuring and read lots of nccam's post's for lots o info and lots of luck to ya!
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 07-15-2008, 11:16 PM
Plastic bearings are actually Nylon Bearings
Mike and ironDigit:
Upon further searching on ebay I find that the "plastic bearings" are
actually "Nylon Bearings" which at least one seller is listing as Precision
Grade 1 Natural Nylon Bearing of 1/8" diameter, quantity of 50 for $5.00
I found that my steel bearings are .1266, so I will probably buy the .1263
size that I found listed.
Thanks for all the input guys!
Jesse
(Java77man)
Ball bearings Syphonics Mechanical Calculations/Engineering Design 4 01-07-2007 05:57 PM
NSK Ball Screws and linear bearings? Burner DIY-CNC Router Table Machines 15 02-11-2006 10:44 AM
Bearings (Radial Ball Bearings) The Bearing Man CNCzone Club House 0 12-18-2005 12:10 PM
Ball screw without bearings? Halfnutz General Metalwork Discussion 6 06-13-2005 03:10 PM
What is recommended for ball screews? Bearings? crazyman DIY-CNC Router Table Machines 16 04-13-2004 07:58 AM
