Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-10-2008, 03:00 PM
CPierce18's Avatar
CPierce18 is on a distinguished road
Rack Spur Motor Sizing help
I’m building a 5’x8’ CNC plasma cutting table and I’ve come to a stopping point. I’m not sure what size rack, gear, or stepper motor to purchase. The gantry itself will end up weighing close to 75lbs, and it rolls very easly over 2”sq. tubing for the X-axis rails. The gear rack will be tack welded to the underside of the tubing (gear rack & motor on both x-axis rails). I would prefer not to have a gear reduction for simplicity (K.I.S.S. – Keep It Simple Stupid). I’ve found internet sites and downloaded stepper sizing programs, but all they seem to be for is stepper’s with lead screws. Is there anything out there for motor sizing for Rack & spur gear? Next, any idea as to what side gear rack to use, and the spur gear for the motor?
How would I figure out these questions?
Here is what I have & need:
Frame Only: 280 LBS
X-axis Gantry Total: 75 LBS
Will be driven by (2) motors (one on each X-axis rail) by Rack & spur gear
-Need stepper motor sizes
-Need rack size/type/dp
-Need spur Size (not worried about a super-duper fine resolution since its plasma)
Y-Axis Total: 25 LBS
Will be driven by (1) motor by rack & spur gear
-Need motor size
-Will use same Rack & spur as X-axis
Z-Axis Total: 10 LBS
Will be driven by (1) 5/16” Threaded Rod Lead screw
-Need motor size
If everyone could give me enough info about all the calculations, I’ll just make a spreadsheet and post it back up here for everyone else to use also.
C. Pierce
Stepper motor sizing Nono Joes CNC Model 2006 1 01-14-2008 10:46 PM
anyone using Rack and spur gears kfranklin Linear and Rotary Motion 8 05-10-2007 08:43 AM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
simple motor sizing smoker Stepper Motors and Drives 5 09-19-2006 04:11 AM
Help with motor sizing flinty Servo Motors and Drives 5 02-08-2005 03:44 AM
