Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-08-2008, 12:51 PM
K Battenbough is on a distinguished road
Question Newby ballscrew Q? Teach lathes.
On a manual/cnc, or teach lathe, im curious to know how is it possible for the saddle to be moved manually via the handle(rack and pinion), when a ballscrew also controls the saddle? wont the ballscrew and nut hold the saddle? Is the ballscrew fixed, and a rotable nut used? I know that the motors hold position in cnc mode, but in manual mode can a ballnut simply be pushed along the screw?
KB
Old 07-08-2008, 01:52 PM
Are you sure the carriage handle isn't a manual pulse generator in disguise? Then the handle would cause motion via ballscrew.
Dick Z
DZASTR
Old 07-08-2008, 02:06 PM
That is true for some makes, but if you look at a haas TL 1,2,or3 it has a rack and pinion on the front.
Heres a pic ive lifted off the web.
KB
MetalWorking Machines / Lathes / Mini Lathes widgitmaster Suggestions for the CNCzone.com site. 0 01-04-2007 05:48 PM
Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW! mxtras General Metal Working Machines 0 03-22-2006 12:43 PM
Lathes, what’s the difference between the different types of lathes out there? MrRage General Metal Working Machines 9 03-15-2006 02:07 AM
Teach Yourself G-Code Switcher G-Code Programing 1 11-20-2005 11:28 AM
Did you know you can Teach Onecnc? HuFlungDung OneCNC 12 05-30-2003 08:08 PM
