Results 1 to 2 of 2
Thread: Can worn out balls in THK bearing block be replaced ?
    Dec 2005
    netherlands
    Vroemm.
    Registered LeeWay's Avatar
    Jun 2004
    Yes they can. It's not that difficult to do on trucks. It is more difficult on ball screws, but still doable with some.
    Remove one end cap and measure several balls until you are sure you have the dimension. Then order some. Make sure you count the balls on each side. This will work fine as long as the rail isn't worn. I think the rails in THK are harder than the balls, but not certain. I do have a small set where the balls are football shaped, but the rails appear fine.
    Lee
  1. Need to refill a linear bearing (lost my balls)
    By sswitaj in forum Linear and Rotary Motion
    Last Post: 05-11-2008, 10:18 PM
  2. How to cut a bearing block ?
    By ringram2077 in forum General Metalwork Discussion
    Last Post: 04-02-2008, 10:49 PM
  3. Replies: 40
    Last Post: 02-07-2008, 06:03 PM
  4. Help with bearing block
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 05:47 PM
  5. Odd THK linear bearing with missing balls
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 07-06-2007, 09:02 AM
