Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-13-2008, 02:18 AM
RiseUp is on a distinguished road
Lightbulb New[ish] bearing slide idea
Hey guys, Im new to this forum, but I thought that I'd throw my idea out there and see what you all think;
I've seen a design somewhat like the first and another variation like the second. (both somewhere on this site; i think the guy's name who started the post was m-something...it was "crazy idea _ _ _" or close to that) and I came up with a different variation that, since it has room for rail supports, allows for the use of a smaller diameter rail, and with a smaller rail, the leg lenght of the angle can decrease.
ID:	61425   Click image for larger version
ID:	61426   Click image for larger version
Name:	Trinity Bearing Slide Design.JPG‎
Old 06-13-2008, 08:17 AM
MrKal is on a distinguished road
Hi there,
I think it's an interesting idea, at least with the last two drawings.
I dont think the U bolt will work because it wont be threaded all
the way around like that, and if it was made out of threaded rod
stock when it was bent the threads would be closer together on
the inside of the bend than the outside of the bend and thus nuts
would not work after the bend. Maybe if it was bent in the shape
of the capital letter "A" with a flat top so that all the sides are
straight so the nuts would turn properly.
The other two ideas look workable though. Perhaps some method
of adjustment so that the wiggle room could be reduced, as it could
be very hard to construct all those parts to exact specs without a
machine shop on hand.
Old 06-13-2008, 12:37 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hello RiseUp. Welcome to the Zone!
This idea looks very promising--Please keep us posted.
CR.
Old 06-13-2008, 01:14 PM
MrKal, the first and second drawings were from another post[that I can't seem to find]. As far as the u bolt idea, it was discussed that using spacers[washers] to keep the bearings in place rather than threads and bolts. Im not sure if anyone has done this, but Im in the process of building mine,and plan on using my design.[third pic]
Old 06-13-2008, 10:40 PM
Hi again Rise,
Sounds good, i would like to hear more about this too and how you
progress with this idea.
Old 06-14-2008, 02:18 AM
Well so far, I already have enough bearings to try my hand at building this (I skateboard as well) and I've ordered angle aluminum and rods from McMaster-Carr. They should be here within a few days. I would've gone to the LHS, but $27.99 for aluminum angle that only has 1 1/2" legs and is only 5' long is rediculous. I couldn't convince myself it was worth it. SO, I came home and ordered twice that amount from Mcmaster .
Tags
bearing, rail, rail support, slide bearing
Question about hole sizes on Bearing Slide Assembly kevperro Joes CNC Model 2006 2 04-16-2008 06:33 PM
THK slide bearing Bill Davis Mechanical Calculations/Engineering Design 2 08-26-2006 06:31 PM
Linear slide idea and questions posix DIY-CNC Router Table Machines 14 01-31-2006 10:56 AM
new ACME rod bearing nut idea (maybe) GregMM Linear and Rotary Motion 2 10-08-2005 05:58 PM
linear slide idea noid DIY-CNC Router Table Machines 16 07-20-2005 10:31 PM
