Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-09-2008, 10:47 AM
kayb33 is on a distinguished road
CNC Problem
Simply put, My rotational input is x degrees and the output displayed on the screen reads x (+/- 0.007-0.010).
Is this a soft problem or mechanical? I'm thinking hysteresis or something along those lines. This ever happen to anyone else?
It's been going on for months but we're a small company and tech fees would be through the roof.
Old 06-09-2008, 11:07 AM
Al_The_Man's Avatar
What controller??
Servo's or steppers??
Rotary axis or Linear??
Original controller or Retrofit??
Old 07-15-2008, 08:58 AM
guru_florida's Avatar
guru_florida is on a distinguished road
In CNC, your use of the term hysteresis is known as backlash. I assume you are talking about when the machine switches directions and the amount of distance the screw must travel before it 'picks up' the table again.
The backlash wont show up if you are traveling in only one direction, and then measuring. If you have error while traveling in only one direction then it's probably due to error in your leadscrew, ballscrew or whatver is used.
The rigidity and alignment of the machine construction will also have a play on the error too. A simple way to correct this would be with shims.
machine problem or software problem? bcnc Syil Products 8 10-26-2009 09:51 AM
