Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-19-2008, 10:18 PM
kingpav is on a distinguished road
Lead Screws
Does anyone know the approximate cost of 8' lead screws with a pitch of approx 0.5" to 1" or there abouts?
I can imagine these things are a bit of a rip off but it would be good to get some figures.
And failing this does anyone have any links to a reliable pin and rack setups so I can investigate those please.
Many thanks,
Paul
Old 05-22-2008, 07:35 PM
Thazul is on a distinguished road
Roton has 1" 2 turns per inch @ $20.86\ft, 1" 1 turn per inch @ $23.94
McMaster.com has 1"-4 2 start, which is 2 turns per inch. but I don't see it listed any larger than 6'.
Maybe you could call them. The 6' piece @ mcmaster is $103.49
I'm sure there are a few more sources floating around on the forums here, maybe someone else will chime in.
Best Regards,
Andy
-edit- Woops! I just realized you're in the UK
The only place I can think of off the top of my head that ive seen is Marchant Dice aka www.worldofcnc.com
I don't see any lead screws close to what you're looking for their, but they do have Rack & Pinion, and Ballscrews.
I'm not sure of your application but if you look at Marchant Dice ballscrews, they have C5 and C7 Class(C5 is a bit higher precision/more costly) with 25mm dia/25mm lead.
Personally if I was going to do 8' length, I'd probably go with 32x10 Ballscrew.
Found another site with leadscrews close to what you want, I see 25x10 there: http://www.automotion.co.uk
Cheers
Last edited by Thazul; 05-22-2008 at 07:52 PM. Reason: Woops! I just realized you're in the UK
lead screws Runner4404spd General Metal Working Machines 4 02-07-2008 08:36 PM
Where to buy lead screws? eldruida Linear and Rotary Motion 1 09-24-2007 06:33 AM
1 or 2 lead screws spoolin_20b DIY-CNC Router Table Machines 6 03-22-2007 04:50 PM
Twin lead Screws Joe_CNC Employment Opportunity 3 04-09-2004 12:18 PM
Lead Screws mdframe DIY-CNC Router Table Machines 14 03-21-2004 08:20 PM
