Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-30-2008, 10:28 PM
endgrainguy is on a distinguished road
Mcmaster antibacklash nuts?
Would these be effective antibacklash nuts for a medium duty woodworking y axis (moving table) http://www.mcmaster.com/ part # 6350K192. Thanks! Need 5/8", and can't find another source.
Old 05-01-2008, 09:26 AM
One of Many is on a distinguished road
They should work fine IF you can keep them clean.
My experience with this "Self adjusting" style, is in cutting phenolics. Fine dust environment on an open Y axis screw would contaminate the nut, which caused the compensating end to grip the screw, tightening the nut and stall the servo in one direction. It just needs flushed out periodically with brake cleaner as these are dry run and oil creates a dust magnet for greater accumulation. They do not mention the limitations with high speed rapids on long runs either. No big deal on smaller machines, but our 4' of Y travel at around 200IPM sure generated a lot of heat in a short period.
For the money, they are hard to beat and simple enough to replace.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
need affortable antibacklash screw setup 60 inches long skydemon DIY-CNC Router Table Machines 2 09-04-2007 09:36 PM
Simplest, Cheepest, Quickest Antibacklash nut P.Passuello Linear and Rotary Motion 3 08-16-2007 12:01 PM
HDPE alignment blocks & antibacklash nuts request Jtheletter JGRO Router Table Design 7 01-22-2007 08:51 PM
Loading Antibacklash Nuts sdantonio Polls 6 01-08-2007 08:01 AM
Uhmw Or Delrin Or Nylon For Antibacklash Nut? ljoe1969 DIY-CNC Router Table Machines 4 11-19-2003 03:39 PM
