| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hi, Where is a good source for the angular contact bearings rated for ball screws? There is VXB bearings on ebay but I dont think they have suitable ones for ballscrews. I hope there is a source out there with overstocked or economical bearings. My ID is 8mm or .315inches. OD is not so important as I havent made the bearing mounts yet. My desired overall tolerance is 1mil on the machine. I have *used* T3 ball screws with .0004 max axial play. Thanks, Colin |
| You could check ebay for good deals. http://www.bearingsdirect.com/ should have what u're looking for. you could also check mcmaster.com http://www.applied.com/ will have what u're looking for. You probably want a set of bearings with the preload built in (no spacers required). For A/C ballscrew bearings, the higher the contact angle the better. 25o and 30o are what you want...but 15o may suffice. |
| Thanks guys, but those bearings are over 150$ for single row. I cant spend over 600$ just for bearings. I guess I am left with whatever I can find on ebay. Can't find anything in 8mm yet. |
| angular contact bearings, or not | klick0 | Linear and Rotary Motion | 23 | 04-11-2012 10:49 PM |
| why angular contact bearings for X3? | lagfish | Benchtop Machines | 6 | 01-08-2008 05:12 PM |
| angular contact bearings ( 8mm id ) | veteq | Linear and Rotary Motion | 4 | 12-18-2007 11:19 PM |
| Angular contact bearings | martinw | Mechanical Calculations/Engineering Design | 38 | 12-26-2006 06:35 AM |
| Ball screws and angular contact bearings? | dowling177 | Mechanical Calculations/Engineering Design | 1 | 01-27-2005 03:21 PM |
