| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I know there can be some problems with long lead screws. Is there a length when this starts to be an issue? What kinds of problems do you start to see? Are there things I can do to help to try and mitigate it? My goal is to be able to cut blanks for skis/snowboard/kiteboards up to 160cm. So for that I would need a min cutting area of 20 inches x 62 inches. Thanks! Bryce |
| At higher speeds, screws start to whip. Screw manufacturers have critical speed charts. Above these speeds is where problems occur. You can find a chart at www.nookind.com
| Thanks for the link! So using 1/2-10 acme I could get something like ~40-50 ipm max on that axis if everything is working OK. Probably run it at less then that as a safety factor. That would still be pretty good in my situation. I suppose if I ever wanted to go bigger or faster then I would have to make the switch to rack and pinion? |
| Don't use 1/2-10 single start acme. Use 1/2-8 2 start, 1/2-10 2 start, or 1/2-10 5 start. Check out the Joe's Hybrid machines people are building. You can get around 300ipm with 1/2-10 5 start acme.
| Acme Screw - Length | jeffserv | DIY-CNC Router Table Machines | 5 | 12-20-2007 01:25 AM |
| lead or ballscrew length | woodrow | Linear and Rotary Motion | 2 | 04-24-2006 11:58 PM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 11:23 AM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 08:42 PM |
| Ball Screw and Lead Screw | ljoe1969 | DIY-CNC Router Table Machines | 9 | 11-21-2003 08:06 AM |
