Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-20-2008, 05:11 PM
gopher's Avatar
gopher is on a distinguished road
DIY acme die / tap
i think i posted this in the wrong area so here it is again....
this is not for a cnc but a special project that will require motion in opposing directions from the same leadscrew so i figure i will have to make my own.
i see a way to make the nuts from derlin, but i wonder how to make the lead screws? is there a special die that i need?? Looking to make 3/8 - 6 leadscrews.
Old 04-20-2008, 05:16 PM
ger21's Avatar
You can buy acme screws that have both left and right hand threads. Is that what you want? Nook makes them. www.nookind.com
Old 04-20-2008, 05:20 PM
gopher's Avatar
yeah 1/2 of the screw would be RH the other half would be LH
that way when the screw rotates the nuts either get closer or farther away depending on which way its turned...
I want to be able to make something and not buy $$ is a issue....
Old 04-20-2008, 06:13 PM
ger21's Avatar
I think you'll need a lathe to do that. Unless you can pull one from a woodworking clamp.
http://www.woodcraft.com/images/products/143628.jpg
Acme rod? grahamshere Canadian Club House 19 02-08-2008 07:40 AM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
acme rod tomcook Linear and Rotary Motion 7 03-24-2006 05:55 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
Acme Tap georgebarr DIY-CNC Router Table Machines 14 02-25-2004 11:06 PM
