Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-15-2008, 08:08 AM
chrugel is on a distinguished road
Ballscrew thrustbearing support?
I've been reading quite a lot about ballscrew end-supports lately and can't seem to find much infor about the use of regular thrust bearings for this purpose.
Is there any reason why this shouldn't work?
This must be a rather cheap solution compared to angular paired bearings?
I paid about 4$ each for 8mm thurst bearings from smbbearings.com
See attached drawing.
The reason for using a retainer ring is so i still can use the axel for my US digital on-axel-encoder. This would be difficult if the axel were threaded??
regards
Chris
Name:	Thrust bearing setup.jpg‎
Old 04-20-2008, 05:43 AM
jacek.jerzy is on a distinguished road
Ball thrust bearings for ball screw support
In fact this type of bearing arrangement was used by many machine tool manufacturers in the past. I have seen exactly this arrangement on an older Mazak M4. The reason why machine tool manufacturers have changed to angular contact ball bearings is that angular contact ball bearings allow much higher rotational speed which is required for fast rapid feed.
Old 04-20-2008, 08:57 AM
Also improved accuracy and fewer parts.
DZASTR
Support Brendan Milltronics 1 03-17-2008 09:31 AM
Need Help!- PC CAM support tengo8 Bridgeport and Hardinge Mills 1 03-03-2008 06:25 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
Cheap source for Ballscrew Support Blocks? geocentric Linear and Rotary Motion 3 06-29-2006 07:00 AM
ballscrew support idea / advice please DrStein99 Linear and Rotary Motion 8 04-29-2006 12:11 AM
