| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hello all, I am getting ready to build my very first CNC machine. The one i am going to make first will be just a 2 axis laser cutter/engraver. The laser itself is very lightweight and power rating is under 2w. i plan on moving the laser head, not the table. I have extracted some stepper motors and a servo from printers that i believe will work fine since the laser head is very lightweight. After i complete this one, i will be building a much stronger 3 axis machine with a drill. My question is: I dont know how to acurately connect the motor to the drive plain for physical movement. I read about people using a certain pitch screw and setting the steps to 1:8 or whatnot. i dont know how to connect the motor to a belt and achieve precisesly measured movement. so what do i need to know to make sure the CNC program (i want to use mach3) is matching with the distance of movements?... if i get code generated to cut say a 2"x2" square... how do i match that up so that 2" in the program really does equal 2" of movement of the laser head? seems to me if i use the wrong size gear wheel on the end of the stepper motor, i will not be able to get the desired movement measurements. im geussing theres some simple math to calculate this? Sorry if im being confusing, this is a bit new to me so i dont know how to properly reference things. ![]() Any help is appreciated |
| also, i dont fully understand what mechanisms are available for connecting the motor for an axis. i hear of rack and pinion, belt drives... and i guess i dont know what else is available or why i would chose between one or the other |
| What motor, screw and gearing should I choose? | arvidb | FAQ of CNC Machine building | 10 | 08-17-2010 11:54 AM |
| What motor, screw and gearing should I choose? v1.2 | arvidb | FAQ of CNC Machine building | 1 | 03-12-2006 03:30 PM |
| What speed and pitch ball screw | George | Benchtop Machines | 0 | 01-08-2006 12:14 PM |
| What motor, screw and gearing should I chose? | arvidb | DIY-CNC Router Table Machines | 5 | 09-03-2004 04:08 PM |
| Ball screw size/pitch? | jakk100 | DIY-CNC Router Table Machines | 7 | 06-18-2003 10:21 AM |
