Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-02-2008, 02:55 PM
macona is on a distinguished road
I WANT to backdrive a ballscrew
I am doing a partial CNC mod on my Monarch 10EE lathe. I want to keep it usable as a manual lathe as well. What I want to do is use a higher pitch ball screw for the carriage and be able to back drive the screw when I am using it in manual.
What pitch would I need to use to keep resistance down?
I am driving with pretty high resolution AC Brushless Servos so I can belt them down quite a bit to bring up the torque. Max speed of ~3000 RPM at 400W output. I figure I could use an electromagnetic clutch to separate the screw from the motor gearing if need be.
Old 04-02-2008, 03:13 PM
samco is on a distinguished road
10EE are great! We have toyed around with cnc'ing ours also. (some would think that would be sacrilege). I (in my opinion) would not be worried about manual use. If you really think you will be manually running the lathe - get 2 jog wheels and have some 'virtual' knobs.
Similar to
http://www.centroidcnc.com/cncvideo/videolathempg.html
sam
Old 04-02-2008, 07:37 PM
Yeah, the EE is a great machine. Got it last summer and have gone through it. In the process of replacing the motor-generator drive with a AC Brushless Servo.
I am planning on doing the conversion so it is as unnoticeable as possible so I dont want to go that route. I want to be able to use it totally without a computer. For the X axis I plan on mounting a ball screw assembly in the place of the taper attachment mounting in the same location.
I just remembered I have a ballscrew that might work for Z. If it will not backdrive easily I will come up with a locking slide where I can just unlock the carriage from the ball screw.
Ballscrew andersbrun Linear and Rotary Motion 2 01-05-2008 12:23 PM
Ballscrew ? Nut? pointcloud Mechanical Calculations/Engineering Design 6 04-26-2007 12:46 PM
Another which is better R&P,Ground ballscrew,rolled ballscrew,Acme,beltdrive etc.thre lgalla Linear and Rotary Motion 10 01-16-2007 11:27 AM
Ballscrew diy?? lolailando Linear and Rotary Motion 2 11-23-2005 11:51 AM
My new ballscrew lt paul General Metal Working Machines 1 07-24-2004 11:35 AM
