| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hi, I have some 25mm ballscrew stock without nut. I am thinking to make a tap from a short piece of the ballscrew and then tapping it to a thick block of plastic (acetal maybe?). Is it worth to try? What will be the problem? -ichan |
| i guess that if it's a precisionrod you should atleast gain precisionmovement ,though you won't be able to profit from low-friction ballscrewaction like mentioned. There shoul be absolutely no PROBLEMS so from my point of view if your expectaions aren't set to high you can'be disappointe and might very well end up with a nice precision leadscrew. from theory i would say you will suffer less efficIency then even a acme leadscrew and nut meaning you'll need bigger steppers/servoos to accomplish same movement in length and speed when using acme and WAYYYY more offcourse when using ballscrews and nuts. I don't think that's even a pence worth ,
__________________ Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol. |
| You could possibly turn it into a lead screw. If you kept it as a ball screw, the metal balls would eat through the plastic nut in short order and you would constantly be replacing the nut. If you just have a stanard ball screw, and you know who the manufacturer of the screw is, you can order just a replacement nut. |
| Thanks to all the good points. The reason behind the idea is I am now don't have any budget to buy the nuts .The expectation is not high and I have some oversized stepper motor for this. Before the last comment above, I was still thinking about how to reduce the friction, shown as image attached. Then I tend to agree with the last comment, the surface contact area is small compared to a lead screw. Now kicking myself out from this idea. -ichan |
| I got acetal nut with acme rod 1/2inch 10tpi. cant feel any backlash seem to hold on nicely on home made cnc router. P.S. got the nut on ebay for 5 buck and acme locally. not worth the trouble of tapping. Just not shure the tread on ballscrew are gonna be efficient with just a nut... |
| Rotating ballnut? | cncuser1 | Linear and Rotary Motion | 80 | 02-16-2008 03:29 PM |
| Ballnut wipers | Zumba | Linear and Rotary Motion | 2 | 12-30-2006 04:24 PM |
| Ballnut lubrication | Haydn | Linear and Rotary Motion | 3 | 12-07-2006 08:36 PM |
| 16mm ballnut? | phantomcow2 | Linear and Rotary Motion | 2 | 02-17-2006 10:56 AM |
| Need a ballscrew and ballnut | trungsy | Linear and Rotary Motion | 6 | 10-29-2005 06:34 AM |
