Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-24-2008, 02:19 PM
designer is on a distinguished road
BALL SCREW TO MOTOR and bearing Question
hI,
I have 2 ball screws with 22mm end that I need to connect to stepper motor
shaft 11mm, I dont want to grind the ball screw down to 12 mm so I need a couple of spider type zero back lash couplings that are not to expensive, can you advise me where to source.
also does it matter about the angle of the double row angular contact bearings
when used with ball screws.
thanks in advance for help.
Old 06-12-2008, 08:52 AM
springlakecnc is on a distinguished road
First of all, did someone size the motor to your machine? Direct drive was popular back in the stepper motor days, now with DC and AC servos, they usually use a timing belt with gear reduction so the motor makes about 10 turns per inch. Unless you have stepper motors, direct drive may be like taking off in 2nd gear in your car! Try http://smp.applied.com/, they sell everything you need.
secondly, heck ya it makes a differance how you install the bearings! on ANY thrust bearing, look at the outer race, one side will be thicker than the other. The thick side of the outer race of the 2 bearings wants to be "back to back", that way you can push them in and out of the bearing journals. Also if they are not "back to back, but both aimed the same direction, they will pop apart when you are machining, and you will have bigtime backlash.
Good Luck with your prodject
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
bearing lock nut on ball screw, how to? replicapro Linear and Rotary Motion 1 01-10-2006 07:28 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 02:03 AM
strange bearing preload threads on ball screw mxpro32 Mechanical Calculations/Engineering Design 1 03-10-2005 08:07 PM
