Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-21-2008, 10:53 PM
endgrainguy is on a distinguished road
pitted ball screw
I just received a used ball screw bought off you-know-where. The screw (no name on it) is a 26" long 3/4" OD, 2 start, .5" travel per revolution. It seems to have no backlash, and turns very smoothly, except in two or three areas, a few inches apart from each other, where I can see minor pitted spots on the troughs of two or three of the threads, -- actually seems to be every other thread in these spots. It still turns easily through these areas, but i can feel a little resistance in these spots. This router is to be used for woodworking, though planned to do inlay, so reasonable precision will be required. Are these pitted areas apt to cause a problem? Can they be smoothed out somehow (with a round file, perhaps?) or would that make things worse? Thanks!
Old 03-23-2008, 11:42 AM
thebodger@roger is on a distinguished road
What ever you do, don't use a file! Try to smooth down any high spots or damage with a fine honing stone and oil. Atlernately wrap some very fine emory paper around the round file, use oil as a lubricant, and slowly and carefully try to blend it out. Clean the surface and test how it runs often as you smooth it.
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
