| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| I was hoping that someone could shed some light on this. I was going to use two 3/4" rods and a 7" dual bearing on each side of my X. I wanted to have them 6' long. My Z&Y weigh about 50lbs. It seems like there is some sagging in the rail at mid point. These are thompson brand rods and bearings. Will they work at this length. Has anyone else did this. Thanks Ed |
| Even at 3' you'll probably get more sagging and flex than you'd like. If you want good results, you'll really need to support the rail and use open bearings.
| I think Gerry is correct. I think unsupported rail would work the best in a very short run. Either a very small machine or on a Z axis only. There is a lot of flex even in solid ground and thick rod. There can be lots of stress on parts of a machine, especially a cutting machine. You can get away with lighter built machines for plasma, but a cutting machine will stress every axis at some point.
__________________ Lee |
| Cutting hardened Thompson Rail. | pbunnstf | General Metalwork Discussion | 5 | 07-09-2007 07:19 PM |
| Need Help for Thompson Grinder | hanpeidong | General Metal Working Machines | 0 | 05-24-2007 09:21 AM |
| Thompson Rod T Supports?? | fritts | Linear and Rotary Motion | 1 | 04-20-2006 06:25 AM |
| thompson shaft and bearings | corrie | DIY-CNC Router Table Machines | 5 | 07-01-2004 08:32 PM |
| thk versus thompson | newguy | DIY-CNC Router Table Machines | 5 | 04-19-2004 12:45 PM |
