Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-15-2008, 10:01 PM
jvfc is on a distinguished road
My Skateboard Bearings system design
I would like to sharing my system design, I think that it is easy for build and work very fine.
Name:	xxx 004_2.jpg‎
ID:	55575   Click image for larger version
Name:	xxx 003_2.jpg‎
ID:	55576   Click image for larger version
Old 03-16-2008, 07:33 AM
Splint is on a distinguished road
It looks good JV, maybe not the best design for some people because they may not have th equipment to fold the thick plate steel. Very good though.
Old 03-16-2008, 11:44 PM
zhagoox is on a distinguished road
Excellent! How precise is that? I have tons of bearings that I would like to put to a good use...
Old 05-02-2008, 02:40 PM
Riceburner98 is on a distinguished road
I realize this post is a couple months old.. But I just took apart a big old optical disk drive (pre-cursor to CD Rom drive) that used this same setup, of course with smaller bearings. There is a bunch of pre-load on the bearings to eliminate slop, but the rod slides through with no resistance. I had thought of using this method for my mill before I found a good deal on some pre-built linear slides.
Old 10-13-2008, 10:11 AM
john robin is on a distinguished road
GOOD NEAT DESIGN LIKE YOUR WORK JV. MADE A TABLE SOMEWHAT LIKE YOURS.
Old 10-13-2008, 04:48 PM
ahren's Avatar
ahren is on a distinguished road
How do you adjust the load of the bearings? Just by moving the single bearing section up and down? Looks like another nice implementation of a ball bearing solution for low cost linear motion. Is that wooden cable track I see in the background as well? That looks pretty cool...
Ahren
www.cncrouterparts.com
Skateboard Bearings luther Linear and Rotary Motion 22 03-18-2008 04:07 PM
Skateboard ABEC-7 bearings coolman Linear and Rotary Motion 7 10-17-2005 03:14 PM
Rails to bearings to carriage to... drive system? Losos DIY-CNC Router Table Machines 2 01-11-2005 12:40 AM
The truth about skateboard ball bearings Swede DIY-CNC Router Table Machines 24 04-16-2004 05:21 PM
