Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-15-2008, 09:58 AM
SPEEDRE is on a distinguished road
Gas Shock Question
The last post was very confusing to me and not so conclusive an answer. So here's my question. I want to put two 30 lb.shocks, one on each side of my square column. Do I get 60 lbs of lift out of this or just 30 lbs.? This is for a manual machine. Just need some resistance so I can use the head without it falling to the table.
Old 03-15-2008, 10:14 AM
Two side by side give you 60, the two shocks add together.
Think about it this way; You can lift 100 lbs, it would need two of you side by side to lift 200.
Get a few bungee cords and experiment; they extend not compress but the priciple is the same.
Gas shock for Z- axis maxboostbusa Benchtop Machines 4 01-30-2008 06:22 PM
Power Supply / Shock Hazard...? whidbey88 CNC Wire Foam Cutter Machines 2 12-13-2007 10:39 AM
Gas shock on knee - how? txcowdog Bridgeport and Hardinge Mills 1 03-28-2006 09:44 PM
