Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-14-2008, 04:51 PM
*Registered User*
ozturbo is on a distinguished road
Rack and Pinion
I have a question about getting the proper spur gear to run on the rack
I want to use the Gear rack shown here:
http://stdsteel.com/gr_stock.htm
Item 200011
and this gear:
part # S1166Z-024A012
from
https://sdp-si.com/eStore/
What i don't know and can't find is if the rack and the gear having a different diametral pitch will work.
Old 03-19-2008, 12:43 AM
yukonho is on a distinguished road
Pitch is the one thing that MUST match for rack and pinion to work. Using different pitches is the same as using the wrong nut on a leadscrew.
Colin
Old 03-19-2008, 06:31 PM
harryn is on a distinguished road
Hi Ozturbo
I looked at the options from sdp and std steel - there is remarkably no obvious compatible gear for the racks listed (at least in the general range typically discussed here). I might be searching wrong, but I did not find a match.
In addition to D pitch, you also need to match pressure angle.
I have seen more options from boston gear's catalog that will cover you. Their list of stocked spur gears is amazingly complete. They also sell rack.
I found it quite valuable to read Boston Gear's literature on the 14.5 degree vs 20 degree pressure angle. www.bostongear.com
Old 03-19-2008, 07:20 PM
liquibyte is on a distinguished road
Well, that was informative. See this pdf for some nice in depth gear theory.
rack and pinion luther DIY-CNC Router Table Machines 8 07-06-2007 10:53 PM
Rack & Pinion john robin CNC Plasma and Waterjet Machines 2 06-29-2007 10:37 AM
Rack & pinion coolman DIY-CNC Router Table Machines 6 05-07-2006 04:14 PM
rack and pinion planescott Mechanical Calculations/Engineering Design 4 10-11-2005 03:28 AM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
